of this great
online community.
LaMort
Reg: 02-14-12
02-19-12 09:51 PM - Post#2192743
In response to 355Cheyenne
Thanks for the response but I went over all of those with my original post. The hole is plugged, there is no wire in the harness for the ESC or knock sensor (I even cut open the harness to see if the ends were cut off.), and there is no ESC module bracket or wire connected to terminal B7 on the ECM for the ESC. Even the intake bolts are bolts, and not studs in the ESC location for mounting a bracket like the 4 other brackets on the intake and they match the other intake bolts (same paint and flange size/markings.) I believe it just wasn't there on this truck. I looked at the forum link recommended above and have done some more browsing, and believe there was some reason for some vehicles to have this omitted. I just want to find out why, now, and how to make mine run properly. I'm thinking this 1228747 ECM may be the key.
