Username Post: Lubrication Troubles
2blu52
Reg: 03-12-02
03-16-10 09:07 AM - Post#1881026
    In response to Danspeed1
30wt will not hurt an older chev in line engine. The main problem with 30 wt is it does not flow well at cold temps and there for the splash system of lubrication does not function well. I have been running 10/30 in my 52 and find that it works very well. As for zinc, it is an additive that is not needed in the engines that we run. I think that if you do a little research you will find that there was no zinc additive at the time these engines were brand new. As said there has been a lot of discussion about Zinc. I do not worry about it with this engine. 50 wt would be excessively heavy.
THOMAS JEFFERSON
Edited by 2blu52 on 03-16-10 09:09 AM. Reason for edit: No reason given.
Execution time: 0.076 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:23 AM
