Username Post: DIY firewall mount power brakes
patgizz
Senior Moderator Member
patgizz
Loc: Cleveland, OH
Reg: 01-30-00
02-12-07 06:53 PM - Post#1094811
    In response to patgizz
next up was find a suitable pedal setup. i had 3 to choose from. 90+ lumina(bad choice). 88-98 pickup(bad choice). and 86 camaro. great fit. i had to cut the clutch pedal and its half of the bracket off the assembly because i have an auto. this bolts to the plate with the same 3/8x1" through bolts that hold the booster bracket on.
a 3/8" rod end(heim joint) was threaded onto the pushrod of the booster, and connected to the camaro pedal. the pedal stock has a pin and the stock pushrod slips over and is clipped on. i ground the weld off the pin and pushed it out and was left with the proper 3/8" hole for my bolt to hold the rod end to the pedal.
backside image shows the pedal assembly is all set to accept a generic GM 2 post brake light switch
the pedal is not long enough stock, i had to bend up a new piece and weld it on to locate the pedal exactly where i wanted it. i may have to snag pictures of that.
this is the finished assembly bolted in
Execution time: 0.129 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:50 PM
