Back to Post
Username Post: Wont start
Jeffrey0180
Posts 32
01-01-18 06:12 AM - Post#2719621
Hey everyone,
I replaced the gasket below my distributor and noe the engine wont start, i brought it to TDC first and marked the location where the rotor was pointing, reinstalled the vap, i did not remove the spark plug wires from the cap. Now she wont start. Where to start searching?
bowtie44s
Posts 3867
bowtie44s
01-01-18 08:40 AM - Post#2719637
If this is a 96 or newer, disregard what I'm about to say. You need a scan tool.
Are you sure you were on TDC compression stroke? If the rotor is under the terminal with the wire going to #1 cylinder, it should start. If it's under #6 you're 180° out. Check the firing order. 1-8-4-3-6-5-7-2.
Jeff
Jeffrey0180
Posts 32
01-01-18 08:52 AM - Post#2719640
Does the pointy end need to be under spark plug wire #1 or the dull end?
bowtie44s
Posts 3867
bowtie44s
01-01-18 09:34 AM - Post#2719645
The metal end.
Jeff
Jeffrey0180
Posts 32
01-01-18 09:42 AM - Post#2719648
Okay, then i installed it backwards lol, gonna pull it out again and get the engine to TDC and hope she fires up. I can re use the gasket right?
CowboyTrukr
Posts 3908
CowboyTrukr
01-01-18 09:51 AM - Post#2719651
Once you get it started, you’ll likely need to set the cam retard angle with a scan tool. There’s instructions on how to do that in the FAQ section in his forum.
Greg
'00 Explorer XLT 4.0 V6 Auto
bowtie44s
Posts 3867
bowtie44s
01-01-18 09:54 AM - Post#2719653
I must have missed it. I never did see what year it was.
Jeff
Jeffrey0180
Posts 32
01-01-18 10:25 AM - Post#2719660
Its a 94’ tbi
Jeffrey0180
Posts 32
01-01-18 10:27 AM - Post#2719661
I do not have the scan tool, will i be able to do it by hearing?
Chevytech
Posts 3733
Chevytech
01-01-18 10:36 AM - Post#2719665
On a 1994 TBI the timing is set with a timing light. It is newer trucks that are set with a scan tool.
To set the timing you will need to unplug the set timing wire and on a 1994 it is in the cab by the computer.
Set timing wire photos:
Set the timing to zero degrees BTDC if it is a small block.
Jeffrey0180
Posts 32
01-01-18 10:40 AM - Post#2719666
Is this wire behind the glovebox? Or beneat the steering wheel?
Chevytech
Posts 3733
Chevytech
01-01-18 10:42 AM - Post#2719667
I just updated my last post to include a link with good photos by Richard.
Jeffrey0180
Posts 32
01-01-18 11:10 AM - Post#2719674
Aha i see, why exactly do i need to pull this wire?
bowtie44s
Posts 3867
bowtie44s
01-01-18 11:45 AM - Post#2719679
You need to unplug that once it is running to set it exact. You need to get it running first. Roll the crank to TDC compression stroke and get the rotor as close as you can to under the #1 plug wire. You will have to mark something pointing to where the rotor is besides the distributor body and rotate the distributor to where it lines up. That should get you close enough to start, then you need to do what chevytech said.
Jeff
Jeffrey0180
Posts 32
01-01-18 12:21 PM - Post#2719684
So for finding tdc on the compression stroke, whilst holding my finger on the spark plug hole it should start pushing my finger off right? And then keep vranking till the timing mark on the wheel lines up with the toothed indicator?
bowtie44s
Posts 3867
bowtie44s
01-01-18 12:50 PM - Post#2719687
Yep. Use a ratchet or breaker bar. The starter will go way too fast. You may need someone to put their finger over the hole and watch the mark. The easiest way I have found to get a ratchet on the crank is take the skid plate off, lay on the ground, and go up through from the bottom. I think a small block is a 5/8 socket and big block is 3/4. Make sure you can read the numbers on the pointer. 0 isn't exactly in the middle.
Jeff
CowboyTrukr
Posts 3908
CowboyTrukr
01-01-18 12:59 PM - Post#2719689
Had my threads crossed. Sorry, guys. Totally wrong on my part.
Greg
Jeffrey0180
Posts 32
01-05-18 01:14 AM - Post#2720064
I forgot 1 detail, she runs on propane gas (LPG). Will she start at 0* BTDC?
Jeffrey0180
Posts 32
01-06-18 08:06 AM - Post#2720200
Ok i got to TDC on 1# and lined the spark plug wire up with the rotor, she still wont fire?
Chevytech
Posts 3733
Chevytech
01-06-18 08:20 AM - Post#2720203
TDC of the compression stroke, or TDC of the exhaust stroke?
Jeffrey0180
Posts 32
01-06-18 10:30 AM - Post#2720215
Compression stroke
Chevytech
Posts 3733
Chevytech
01-06-18 02:00 PM - Post#2720230
Check the terminals in the wiring connectors you unplugged and see if they need to be tighten up to make good contact.
rain_man_rich
Posts 138
01-06-18 09:47 PM - Post#2720291
You have the spark plugs wired on the cap 1-8-4-3-6-5-7-2 in the clockwise direction yes? If yes, do you have spark?
Jeffrey0180
Posts 32
01-07-18 04:39 AM - Post#2720303
Just checked, got no spark. Could this be the ignition module or ignition coil?
Execution time: 0.248 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:54 PM
