Back to Post
Username Post: Timing issues
malibu27
Posts 66
malibu27
12-30-17 04:38 PM - Post#2719461
I've got a problem that is totally beating me. I built a 383 stroker last winter. It's got 10.5 to 1 compression ratio. I run 93 octane fuel. I installed a cheap Chinese HEI distributor in it. I verified that the timings marks are true top dead center. For some reason i cannot advance the initial timing past 0 or it spark knocks like crazy. Even if it's at 2* it'll knock. The only thing i think it could be is that cheap distributor but i figured I'd ask before i spend $500 I a new MSD system.
'83 chevy K20, 383, Scat Crank, Comp Cams 08-408-8, Etec 170's, sm465
'97 chevy 1500 Silverado, 350, 4L60E
Posts 27372
12-30-17 04:59 PM - Post#2719464
What was wrong with your cheap GM HEI distributor that made you want to install a cheap Chinese distributor in order to fix?
If your spark knock is occurring under light throttle conditions, try disconnecting the vacuum advance line before you do anything else. If that doesn't make any improvement, it's very possible that putting some stiffer advance springs in your cheap Chinese distributor can solve your problem. Buy an advance kit and do some experimentation before you lay down $500.
Better yet, find a shop with a distributor machine and find out what your cheap Chinese distributor is doing now before you go inside it.
malibu27
Posts 66
malibu27
12-30-17 05:04 PM - Post#2719465
Some other helpful info is:
The motor is in a 1983 k20
Plug wires are MSD 8.5MM
Heads are Edelbrock Etec 170 64cc
Flattop pistons
malibu27
Posts 66
malibu27
12-30-17 06:58 PM - Post#2719473
the knocking does only occur under light acceleration. I'll try disconnecting the vac advance line and see what happens.
Are you saying that the MSD is a cheap chinese distributor? I've had the same cheap distributor in it the whole time.
Posts 1252
12-30-17 07:26 PM - Post#2719475
With a set back timing lite you can check the advance curve at any point. If the heads are steel, 10.5 compression is tough to control detonation unless you have an aggressive cam.
Posts 27372
12-31-17 12:14 AM - Post#2719497
  • malibu27 Said:
.....Are you saying that the MSD is a cheap chinese distributor? I've had the same cheap distributor in it the whole time.
Nope, I'm saying you should try to fix your cheap Chinese distributor's problems before laying down $500 for the MSD.
Senior Chevytalk Moderator
Posts 24297
12-31-17 06:00 AM - Post#2719506
What type of timing chain/gears are being used? Is the timing chain set advanced? Timing advanced gears are available for use.
malibu27
Posts 66
malibu27
12-31-17 06:53 AM - Post#2719507
I do have a set back timing light. I'll check the advance throughout the curve. The heads are aluminum.
malibu27
Posts 66
malibu27
12-31-17 06:56 AM - Post#2719509
I installed a high quality Cloyes timing set to factory timing. Would it help to pull the crank gear off and install it on the advance keyway?
malibu27
Posts 66
malibu27
12-31-17 07:02 AM - Post#2719512
I forgot to mention that I did already install heavy springs in the distributor. It didn't seem to make a difference. I also custom ground the weights to try and get more advance out of it. I know you normally want around 34 degrees of total timing. Again, grinding the weights didn't seem to make a difference. I was able to get about 20 degrees of advance after I ground the weights.
malibu27
Posts 66
malibu27
12-31-17 07:34 AM - Post#2719515
I found the installation instructions for the Cloyes timing set. Looks like I could try advancing the cam timing to get better low end torque. I wonder how that would affect the spark knock?
http://www.cloyes.com/Images/Instruct/3%20k eyway%2...
Posts 1252
12-31-17 09:41 AM - Post#2719522
Don't change anything til you correct the timing curve issue, I have set up engines like yours with 14 initial and 34 total at 3,000, with no issues, how did you determine piston tdc when checking the balancer to cover tdc mark?
malibu27
Posts 66
malibu27
12-31-17 10:49 AM - Post#2719529
I marked it when i built the engine. And i just checked it again with a scope camera yesterday and its still good.
malibu27
Posts 66
malibu27
12-31-17 12:52 PM - Post#2719541
Ok so i advanced the initial timing to 10* and that gave me 34* total timing at 3,000 rpm. I unhooked the vacuum advance from the carb and plugged the hole. Took the truck for a drive and it doesn't knock under light acceleration anymore. Does that mean somethings wrong with the distributor?
Posts 27372
12-31-17 02:56 PM - Post#2719552
Not necessarily defective, but more likely set wrong. Specifically, your total vacuum advance is either too much (in degrees) and/or is coming in at too low a vacuum value (in inches). You can do a rough check with a vacuum gauge and a timing light. However, it would be best to have this checked on a distributor machine like a Sun or whoever else makes them now.
Posts 1252
12-31-17 03:20 PM - Post#2719558
Agreed, but if it runs strong, forget the vac advance for now.
malibu27
Posts 66
malibu27
12-31-17 07:34 PM - Post#2719596
Yes i will leave it unplugged. What does the vac advance do anyway? Better fuel mileage?
The motor does still ping under hard acceleration but that's because it's going lean. I've got a Innovate Motorsports AFR analog gauge, and a Holley 4150 double pumper. I just got the Holley, changed from an Edelbrock 1405. The Holley pretty much runs perfect out of the box except for hard acceleration. I've got a 50cc accelerator pump and bigger squirters on the way. I'm sure that'll remedy the problem.
Thanks for the help gentlemen
Posts 24297
01-01-18 05:46 AM - Post#2719620
Moved over from the 73-87 Truck forum.
grumpyvette
Posts 17149
grumpyvette
01-01-18 07:57 AM - Post#2719631
you can,t fix a damn thing until you have verified facts and know what your dealing with
start by verifying tdc on the damper and timing tab reflect reality then map the timing curve
reading links may not be fun but it beats not having the car run decent by a long way
malibu27
Posts 66
malibu27
01-01-18 08:19 AM - Post#2719633
Grumpy, appreciate the input. Maybe try reading the whole thread. I marked TDC when I built the motor. Then I checked it again with a Milwaukee scope camera through the spark plug hole 2 days ago. I made sure to check the basics before changing anything.
BTW I read all those articles BEFORE I built the motor. Thank you for helping with those. I really appreciate it.
malibu27
Posts 66
malibu27
01-01-18 08:27 AM - Post#2719635
I found this vacuum limiter from Crane. Anybody use one of these?
https://www.summitracing.com/parts/crn-99619-1
Posts 1252
01-01-18 08:43 AM - Post#2719638
Even with full vacuum at idle soon as you accelerate it would drop back the advance to close to zero, so pinging on acceleration should not be affected by the vacuum advance unless you have it connected to ported vacuum at the carb, instead of manifold vacuum.
malibu27
Posts 66
malibu27
01-01-18 08:55 AM - Post#2719641
I did have it connected at the carb before. Your saying if I connect the vac can to the manifold it might not ping on light acceleration?
The engine does have a high vacuum at idle. It's at 18 inches. When the pinging occured the eninge vacuum was usually around 10 to 15 inches. I have a full time vacuum gauge so I always know what it is.
IgnitionMan
Posts 3303
01-01-18 09:20 AM - Post#2719642
Yes, that is the correct stand alone stop plate, but DO NOT mount it the way Crane says to, that will make things much worse. Crane p/n 99619-1
If you want a complete instructions and pictures package, ask for one, they get the vacuum advance fixed correctly.
Gmvacuumadvancemodificati ons@gmail.com
There is no charge for them, and you can run the correct full manifold vacuum without problems.
Since the stroke on a 383 is long, your 10 degrees is like 14 on a shorter stroke engine, so, you are in the right places for both initial and curve, but not for IDLE.
That engine would like 18 to 22 deg/BTDC @ IDLE, but it wouldn't like it all in initial degrees. So, how to get 10 initial, and, say, 20 idle?
Simple, set the vacuum advance degrees stop to give 10 degrees, and plug the vacuum advance into full manifold vacuum. Engine will start easily, idle timing will be where the engine wants to be, engine will run better.
You definitely want to use the vacuum advance, and need to do the mods before finish dialing the carb in.
I also advise NOT using the dial back feature on any and all non-computerized ignition systems. Add a timing tape, and leave the dial back OFF.
BTW, you mentioned aluminum heads, shoot for 192/195 deg/F. Coolant temp, not cooler. Aluminum heads dissipate heat more rapidly than cast iron, too cold an engine temp with them makes for problems not easily resolve, until the coolant/engine temp is brought up.
malibu27
Posts 66
malibu27
01-01-18 02:43 PM - Post#2719700
Great! Thanks for the info. My balancer is marked all the way out to 50 degrees so I don't have to use the dial back feature on my timing light.
My thermostat is a 180*. I had a 200* Tstat and the engine wanted to diesel when I turned it off. That may have been when I still had the PCV valve hooked up and it was pulling a TON of oil into the intake. I've since deleted the PCV. And the rings have since seated. I did a leak down test and all cylinders were at 2%.
I emailed those guys. Hopefully they get back with me on the modifications. Thanks a lot.
One other thing: I am getting some starter kick back only when the engine is warm. Is that a timing issue also?
IgnitionMan
Posts 3303
01-01-18 05:56 PM - Post#2719719
"Those guys" WHO?
Dieseling can be from a lot of things, like not enough timing to allow the carb to idle the engine down, as you have now with no vacuum advance. Getting the vacuum advance set up correctly will help lower the idle speed by closing the carb down a bit, so it doesn't Diesel the engine, no matter the engine speed.
With hotter engines, incorrect idle speeds, incorrect timing/vacuum advance, and other factors, like carbs not tuned because of the other stuff, yup, idle quality can stink pretty bad.
When you get the vacuum advance and carb dialed, 195 deg/F. will work just dandy.
NO PCV system, NOT GOOD. Most people don't get this right very much, but there are a whole lot of different PC valves, in both vacuum level, and actual air volume flow, get just one of those parameters incorrect, makes for a really unhappy camper.
What specific idle rpms, and, if automatic, in and out of gear, please.
malibu27
Posts 66
malibu27
01-01-18 07:41 PM - Post#2719727
  • IgnitionMan Said:
"Those guys" WHO?
I emailed Dave the ignition guy. He emailed me right back with instructions on how to modify the vac advance.
The PCV system I had was absolutely draining my oil pan dry. I even tried a new PC valve and it still sucked oil through the intake. Now that the rings have seated I guess I could try it again. What happens with no PC valve? Which PC valve is a good one?
My truck idle's at 800 rpm. Manual transmission out of gear. Idle vacuum is 18 inches. Idle quality is very good. My AFR gauge reads 14 at idle.
IgnitionMan
Posts 3303
01-01-18 08:21 PM - Post#2719733
Just whom do you think "Dave the ignition guy" is?
Try "IgnitionMan". Why the special email for the vacuum advance info? Well, a whole lot of people that always recommend their pals for services in topics, got the impression I was "advertising" for my products, when that was the furthest thing from my intentions. As you can see in the info, that is purely to get the vacuum advance correct, no ads anywhere. So, I set up the pictures and instructions email to get the vacuum advance info out, without all the tearful crying, and false accusations.
Hope you take a close look at the info. Should help, it has for everyone that has done it.
Please outline the PCV system you had, valve from one valve cover to vacuum fitting on the carb, other side has a free open inlet hose, air filter base to valve cover, I hope. Because if there ISN'T an inlet for fresh air into the engine, the suction will suck the pan dry.
The keys are, the right valve spring tension for the PCV, and, the correct volume for the valve. Example: I have a 1972 Vega street car, 5 speed, nice rear end, power 4 wheel disk brakes, power/tilt steering, A/C, name it, its there. The engine was a 1963 200 horse all Aluminum Buick 215 V8, 300 aluminum heads, big valves, nice Crower cam, 300 Buick .600 stroker crank, Chevy rods, 305 Chevy pistons, all the good stuff.
That engine had a PCV system that used a 90 degree PC valve, with 16 inch vacuum to match the carb/engine vacuum. But, the volume of pulled air was too great, so, I made an aluminum slug for the vacuum line, with a 3/16ths hole, PCV worked well.
The new engine is a variation of the Buick, Rover 4.6 all aluminum, 300 heads, 300 stroker crank, a different Crower cam, Corvair big valves, welded heart shaped combustion chambers, 305 Chervy pistons, and, a full-on large air meter, 5.0 Mustang EFI nozzle tuned port EFI system that the stock Rover PC valve works nicely with. And, the entire engine still weighs 335 pounds.
What I do is figure out the specifics of the engine, and match up the PC valve I would use for the same scenario in my engine, and go from there. The valve I used in the 215 Buick was from a low horsepower 2bbl 390 FE Ford.
As far as AFR gauges, my take, serious useless, and I use the "read the plugs, look at the exhaust, feel the thing in the seat of your pants" gauge, and it works so much better than all that gauging that wants you to tune it to its whims, not what the engine tells me.
You see, the gauge may well dictate to run this setting, when common sense in the driver's seat screams another setting works better.
I just watched an old "Twilight Zone" with William Shatner. He had car troubles in a small town, and while it was being repaired, he went to eat, and started feeding a fortune telling machine. It got to the point he was feeding pennies into this machine as fast as he could throw them at it, and believing what it was telling him, instead of looking for himself, using his own common sense.
To myself, AFR gauges and dial back features on timing lights are much like that fortune telling machine, stick a penny in, blindly believe what it tells you, not what you can see with your own eyes, and feel with your butt.
Now, please, don't think I am insisting on you doing anything I say, you do as you wish. All I am here to do is help, you go forward from where you are, accept, reject, your choice.
malibu27
Posts 66
malibu27
01-01-18 08:56 PM - Post#2719739
Haha, I figured it was you but didn't want to imply. The PCV system I had was a cheap 90* PCV valve connected directly to the bottom of the carb. No vent on the other valve cover. Probably why it sucked the pan dry. The so-called professional mechanic that dyno-tuned the truck took the PCV valve off and vented the crankcase to atmosphere. I guess that's a no no.
I found this PCV valve. Although pretty pricy, what do you think? Necessary or not?
http://mewagner.com/?p=444
IgnitionMan
Posts 3303
01-02-18 08:35 AM - Post#2719765
No, actually, he probably helped the no fresh air into the PCV system without knowing why.
I'd redesign the system, work it out right, it does help the engine when done properly.
Nope on that valve, it only has a small proximity from one side of itself, to the other, needs suction on one side of the engine, fresh, clean ambient air inlet on the other side, full across the engine air path.
I didn't look, how much is that con job of a "valve"? Gotta be outrageous.
65_Impala
Posts 4002
01-02-18 01:34 PM - Post#2719788
The PCV valve sucking that much oil would tell me you didn't have proper oil baffling for the valve.
malibu27
Posts 66
malibu27
01-02-18 04:24 PM - Post#2719805
The valve covers I have do have baffling. Don't know if it's the correct kind of baffling.
So I did the vac advance modification today just like the instructions said. I put the stop at .110 to give me 10 degrees of vac advance. Hooked it up to full manifold vac. I had 20* BTDC at idle. Took the truck for a drive and it's back to pinging at part throttle.
65_Impala
Posts 4002
01-02-18 04:33 PM - Post#2719807
Only having 10* of vacuum advance doesn't mean it will work. The vacuum where it is added matters too. I've also setup many engines with more than 10* of vacuum advance that worked fine.
Got a vacuum hand pump? Test the vacuum advance to see what vacuum it starts moving and what vacuum it's at full travel.
IgnitionMan
Posts 3303
01-02-18 05:14 PM - Post#2719811
Is this one of the stock vacuum advances, or an adjustable like a Crane?? If stock, the actual vacuum rating of the advance could be a problem if it were too soft. If it is a stock vac adv, please post which numbers/letters are stamped on the mounting plate. I can ID it for vacuum/application.
There are only about 20 stock replacement vacuum advances for each, point and HEI distributors, all have different springs in them, to work with different vacuum ratings. And, different vacuum pulls use different actuation speeds to match the spring set inside them.
As far as the baffle to the PC valve, there is NO reason the baffle would control any PC valve function regarding vacuum, that is in the valve itself, in both the orifice size and spring loading, NOT THE BAFFLE. The baffle separates oils out of the air/oil mix, and allows the oil to flow back into the engine. To make the baffle hold oil to be sucked into the valve, it would have to be filled with oil, and act as a pool for the valve to pull into the valve and line.
Since you had the baffle, I'd have to say it is that there is NO free air allowed into the engine, as I outlined previously, NOT THE BAFFLE.
For the extreme simpleton that posted above, think of it as two straws in a soda cup, both at the top of the cup, closed to the cup, but open on their ends. Neither goes down into the soda. One is suction, one is vacuum. Now, when suction is added to one of the straws, air passes into the cup, aerates with the soda, passes through the baffle, where the main part of the soda is separated from the mix, and dropped back into the cup, and the vapor and air passes to the suction device, and is enjoyed by the sucker.
Now, do the same, but, close off the open air inlet to the straw, and suck as hard as you can, what you get is a lot more liquid soda, not allowed to separate in the baffle, and sucked into the sucker person.
Welcome to PCV-101.
I've said this before about the above poster, and I will say it yet again, I steadfastly refuse to engage in a battle of wits with a completely and totally unarmed person.
65_Impala
Posts 4002
01-02-18 07:03 PM - Post#2719825
Show us a picture of the baffle or at least a link to the valve cover that shows it.
Piss poor baffling is the only reason the PVC will suck the amount of oil you're saying it does. Just compare the little flat piece of tin on some aftermarket covers (ones that actually have one) vs the big baffle in stock GM covers and then still try to claim that aftermarket baffle works as well. You can fix the other cover to add a fresh air inlet, but it'll still be sucking oil from the improper baffle.
Hell, I remember plugging the fresh air inlet as a common simple fix on the old fox body Mustangs. Those EFI Winsor engines sucked oil badly enough many other people would remove the PVC and atmosphere vent the things to avoid the oil buildup in the intake.
The issue you'll most likely have without the fresh air inlet is not properly getting the gases out so the engine builds up gunk. Similar problems happen with simple valve cover vents. Remember the old GM road draft tubes that would actually suck the fumes out of the engine once driving down the road? It was an early fix to keep the engine vented before PCV systems.
I have no idea how no air inlet would make oil flow up...
IgnitionMan
Posts 3303
01-02-18 10:31 PM - Post#2719845
Malibu, let me know, OFF BOARD, if I can help get you dialed in with the right advance can.
Until then, you might take a serration out of the vacuum stop, test, go again until the pinging stops.
In those 20 or so stock vacuum cans, are 20 or so differently set vacuum pull rates, all different. The Crane adjustable can has all 20 settings, and every one in between.
Crane is the only adjustable with the best, widest adjustment spread.
As I asked, what is on the advance mounting bar, please? Stock GM will have three sets of numbers, aftermarket stock replacements would use a letter-number code, like for the large coil in cap HEI, A-1, A-2, A-3, etc. Points cans use a first letter of B, B-1, B-2, etc.
models916
Posts 4774
01-03-18 06:01 AM - Post#2719858
Grinding the weights and stiffening the springs will give you LESS or SLOWER advance. Vacuum advance only works at high vacuum like idle or part throttle at speed. When you nail the gas pedal, you turn off the vacuum advance.
malibu27
Posts 66
malibu27
01-03-18 04:55 PM - Post#2719905
So if I remember right I actually did the grinding on the center metal piece, not the weights. I had never done it before and I was just experimenting. It seemed to work pretty good though.
At idle and WOT the truck is fine, no pinging. It's only at part throttle, 10-15 inches of vacuum that it pings.
malibu27
Posts 66
malibu27
01-03-18 05:00 PM - Post#2719907
Honestly, do I need vacuum advance at all. This is a weekend wood hauling, trailer pulling, fun having truck. Not a daily driver. I'm kind of tired of messing with the d@%! vacuum advance and PCV valve.
Here is a link to the valve covers I have. The pictures don't show the baffles but they do have them.
https://www.summitracing.com/parts/sum-440402
65_Impala
Posts 4002
01-03-18 09:50 PM - Post#2719937
No, you do not require the vacuum advance. It does help with keeping the plugs clean and with fuel economy but the engine will work just fine without it.
Did you verify the canister that came on the distributor isn't adjustable? If it happens to be, you should be able to fix it with a few turns of a hex wrench.
I can see there is something blocking the hole of the valve cover, but no indication of what it looks like on the back side. It does appear the plate is fairly close to the hole so the valve might be close to touching it when it's installed. If the plate shape and position allows the rockers/valvetrain to throw oil up onto the top of it, then some of that oil will easily be picked up as it flows around/past the end of the valve.
malibu27
Posts 66
malibu27
01-04-18 04:05 PM - Post#2720013
I'm petty sure the vac advance canister is adjustable because when i look down the hole it looks like there is a tiny Allen head in there. What does turning it do?
I'll pop a valve cover off and snap a picture of the baffle.
65_Impala
Posts 4002
01-04-18 05:10 PM - Post#2720024
The simple answer is to turn the screw counter clockwise one turn at a time and see if it helps.
Turning it counterclockwise makes it require more vacuum to pull in and advance the timing. So, adjusting it will cut back the total timing at part throttle when you are getting pinging.
Being a China distributor, there may be no info available specifically for that canister. But, it is possible that if you turn the screw too far counter clockwise that you can unscrew the adjuster out of the threads. Just saying to not go too crazy turning it.
If you want to try and avoid unscrewing the adjuster then first turn it clockwise till it bottoms while counting the turns. The, turn it back counterclockwise until it's back where it was. After that, don't turn it a total of more than about 10 turns counterclockwise from the bottomed out position. That should be safe enough to avoid unscrewing the adjuster. For example, if it started out 3 turns from bottoming out then don't turn it more than 7 turns further counterclockwise.
If you wanted to get really fancy, then you could also adjust it using a vacuum pump. But, it's not necessary to do it that way. You just need to be willing to go for a drive after each adjustment.
If adjusting it doesn't make a difference, then I'd change to a name brand adjustable canister.
malibu27
Posts 66
malibu27
01-09-18 05:23 PM - Post#2720601
So i unhooked the vac advance again. I also installed the 50cc accelerator pump with the biggest nozzle holley offers which is a 50. Its still going lean when i hammer it and I'm under 2000rpms. If I'm over 2000rpms it does fine. Anyway to get more fuel at lower rpm?
models916
Posts 4774
01-10-18 06:37 AM - Post#2720663
Holley power valve may not be operating correctly or be of the wrong vacuum setting and holding on to the lean stage too long. Cheap and easy to change out, available in a number of vacuum setting and just screw into the mid plate in front.
malibu27
Posts 66
malibu27
01-10-18 07:20 AM - Post#2720667
I've got the 10.5 power valve and it is working because i can see it open up on my afr gauge. I'm tempted to change to bigger mains but it cruises perfectly at 14 on the afr gauge.
models916
Posts 4774
01-10-18 07:29 AM - Post#2720668
Almost everything I have tuned on in the street hot rod range has gotten a 6.5. Worth a try?
malibu27
Posts 66
malibu27
02-16-18 06:34 PM - Post#2724634
So I just wanted to update this thread by saying I switched over to Holley Sniper EFI with their Dual sync distributor and my truck has never run better. I picked up 50 horsepower and no more spark knocking. I have complete control over my fuel and spark curves now. Should have done it sooner. I will never waste time with a carb and mechanical HEI distributor again.
65_Impala
Posts 4002
02-17-18 08:44 AM - Post#2724677
Good to hear. What you said about never going back is what almost every person who was willing to make the switch to EFI says. Not only will I only run EFI, I also will also only run electronically controlled automatics in any vehicles that will get an automatic.
IgnitionMan
Posts 3303
02-17-18 09:14 AM - Post#2724679
You did the right thing going to the Holley system. I see people go through total hell in trying to get other systems dialed in, when the Holley EFI just plain works.
I am biased, though, I worked at Holley on Pro-Stock carbs for a few years. Their EFI department and techs are the best of the best, bar none.
malibu27
Posts 66
malibu27
02-17-18 07:39 PM - Post#2724722
Yes I thought about getting the Fitech but some of the reviews were bad and the Holley wasn't but another $100 or so. Plus the dual sync allows timing control. I don't think the fitech has timing control and that was a deal breaker for me. Why spend all that money on the fuel side and still have 30 year old timing technology?
IgnitionMan
Posts 3303
02-18-18 09:18 AM - Post#2724750
You are right, today's EFI does need to also fully control the timing parameters as well as the fuel curves.
Carbureted engine, 30 years old timing methods, they work well, but not for sophisticated fuel injection.
I speak with more people really unhappy with their FiTech systems than all others combined. Just shows that over hype advertizing works, in the beginning, but the real story does eventually come about.
CNC BLOCKS N/E
Posts 974
CNC BLOCKS N/E
02-18-18 01:06 PM - Post#2724778
Should not be using a dial back timing lite with MSD unless your using the MSD timing light or the French Grimmes lite.
malibu27
Posts 66
malibu27
02-18-18 06:54 PM - Post#2724808
Thanks but I don't need a timing light at all anymore. Sheeesh
IgnitionMan
Posts 3303
02-19-18 01:45 AM - Post#2724828
I beg to differ, you do still need the light to set the firing reference point for the computer, and to check the curve the computer has, to reset the timing parameters in it as you adjust them.
This is one instance where a dial back light is beneficial.
0utlaw
Posts 2789
0utlaw
02-19-18 03:55 AM - Post#2724837
I've read that MOST old school hi performance STREET ignitions need to have SOME vacuum advance...for cruising and gas mileage.(Not talking about a radical racecar driven on the street)
Vacuum advance should be called vacuum retard...when you step on the gas, vacuum goes nearer to zero and your spark retards to protect your motor. And it helps your motor to run COOLER. But, light throttle knock that you loose with the vacuum disconected is a good sign that you either need to adjust your can (adjustable can) or rework the vacuum advance so it advances LESS.
I have a similar setup on medium springs and I set my timing on 34 degrees at 3000 rpm. I, then installed a vacuum advance that I reworked to move about half-way. (I did this by spot welding a piece of steel to limit the travel on the bench.) Easy to do.
Basically experimenting...no scientific data to support.
So far...
No pinging or knock at all on high test and very responsive.
IgnitionMan
Posts 3303
02-19-18 09:41 AM - Post#2724859
Actually, Ford got it right in naming 'vacuum advance', they called it a "load compensator device".
The points Outlaw made are right on target.
65_Impala
Posts 4002
02-20-18 08:20 AM - Post#2724980
Good point on the MSD since the dual sync distributor needs an ignition box so there is most likely a multiple spark discharge box in use here.
Claims about computer controls and dial back lights are such a joke though. Any time a single spark worth of energy travels down a spark plug wire to the plug it is EXACTLY THE SAME between a computer controlled distributor/coil and a non-computer controlled distributor/coil. An inductive pickup put AROUND the plug wire will pick up the energy from EITHER type the EXACT SAME WAY. The inductive pickup has no clue what upstream controls are triggering the coil and causing that spark to be travelling down the wire.
If certain dial back lights don't work with a single spark ignition it's because the delay circuit in the light is JUNK, not because it's not being used on a computer controlled ignition. Same reason certain lights not working with a multiple spark CD ignition box - bad/wrong electronics inside for the application.
malibu27
Posts 66
malibu27
02-25-18 02:28 PM - Post#2725558
Yes, i did use my timing light to do that. I don't need it anymore though.
malibu27
Posts 66
malibu27
02-25-18 02:41 PM - Post#2725562
So far...
That's why i switched to efi and digitally controlled timing. No more experimenting. I can set my timing to whatever i want it at any rpm and any manifold air pressure. Right now i basically have 18* initial timing. 36* WOT timing. 44* cruising. With a few adjustments in the low rpm and high manifold air pressure range. Obviously all those blend together making a nice smooth graph. I love it! So much easier
Posts 1252
02-25-18 03:20 PM - Post#2725571
Actrons set back lite doesn't work with MSD.
Execution time: 0.332 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:03 AM
