Back to Post
Username Post: Air Conditioner recharge
Buddy Mewbourne
Posts 162
12-07-17 04:08 PM - Post#2717224
I have an after market air conditioner set up in my 39. I need to recharge the system. The quick connect hose that I have won't fit the low pressure outlet on the compressor. Do they make different quick connect fittings? Never run to this problem before.
Second Bridge Garage
Posts 1047
12-07-17 05:45 PM - Post#2717229
Maybe it is the high side fitting? Which won't fit the low side. or you are using old style r12 fittings?
Buddy Mewbourne
Posts 162
12-08-17 01:55 AM - Post#2717269
Thanks Shepard. I'll try that. Don't know if I'm trying to use an old R-12 fitting. I'll check.
Ray P W
Posts 342
12-08-17 09:00 PM - Post#2717371
Buddy,
I have an R12 gauge set that I also use on our R134 cars. All it took to be able to do that was an inexpensive adapter set from O'Reilly Auto Parts.
Ray W
Execution time: 0.303 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:22 PM
