Back to Post
Username Post: You're not going to believe this!
454cid
Posts 297
454cid
09-10-12 05:19 PM - Post#2268495
I've had this truck since 6K,and the truck now has 230K. I had a right hand turn signal out..... it's always the board..... ALWAYS. I didn't even look to see if it was front or rear..... I knew, becasue it's ALWAYS the board in the rear tail light.
I took the right tail light apart..... I actually had a blown bulb! It's probably not an original, since I did replace the bulbs early on, thinking I had a bulb problem, but still, I actually had a blown bulb. I'm amazed. I put another bulb in, and it works. The old bulb was dark.... sooted up, although the filament still looked like it was attached.
It it starts not working in a few days, I'm going to have to retract this, of course....... but normally when it's the board, simply pulling it out of the housing would make it work, and this time that didn't happen.
This is a Dorman board.
99 K3500 RCLB
Execution time: 0.065 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:48 AM
