| Username | Post: Felt seal on 57 shortened column | |
terry's57 Member Posts 10 |
07-30-12 05:21 PM - Post#2253907
Replaced 605 box with cpp500. The shorted auto shift column doesn't have felt seal on inside to keep hot air out. Have ordered felt seal to install. looking for suggestions to keep seal in place or other options to seal inside column area. |
Pistol "11th Year" Silver Supporting Member Posts 3558
07-30-12 05:34 PM - Post#2253916
This is your best bet, itkeeps the shaft centered and working smooth http://www.ebay.com/itm/1955-56-57-Tri-Fi ve-5-Chev...
07-30-12 05:46 PM - Post#2253926
Forgot to mention auto column shift. Is this part compatible? |
07-30-12 05:51 PM - Post#2253930
That might be a problem, I put it in with a floor shifter, I know that there is the stock bushing and this is what it replaces, goes in at the same spot, I cant say for sure Terry sorry
acardon "9th Year" Silver Supporting Member Posts 9458
07-30-12 06:06 PM - Post#2253937
No, that bearing won't work with the shift tube. Why not do it like stock. A felt washer above the shift lever and one below held in place by the cup and a shorter spring between the rag joint and washer cup. .... Link to shaft seal.
07-30-12 06:23 PM - Post#2253945
Thanks Acardon, do both seal the shaft and shift tube. Bottom of column is not sealed around steering shaft, don't know about around shift tube, haven't removed it. Where above shift lever |
07-30-12 06:37 PM - Post#2253957
This one goes above the shift lever and seals between the shift tube and outer mast jacket. ... Link to seal. The smaller one with the cup and spring seals between the shaft and shift tube.
07-30-12 06:54 PM - Post#2253971
Thanks again, took apart this aft. didn't see felt washer above shift lever. Probably left it off last time I had it off. Will order both tonight. |
