Back to Post
Username Post: Spark Plug Application for specific engine combo
weewillie
Posts 54
07-13-12 10:07 PM - Post#2248005
Need help finding the correct spark plug to use.
400 block bored 0.40
350 eagle crank and rods
Ross flat top racing pistons
Vortec cylinder heads
Cam duration: 256 int. 268 exh. lobe seperation 110
Hydraulic lifters, 1.5 rocker arms
Holley 2 bbl carb
Stock exhaust manifolds
HEI distrbutor
Engine will be run on a paved circle track
Execution time: 0.089 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:19 PM
