Back to Post
Username Post: motor and trans mounts swap
995jim
Posts 274
995jim
06-24-12 03:33 PM - Post#2240857
I installed solid motor mounts in my car and need to know if I should install a solid trans mount as well. Ive been told to match solid or match rubber but also recall being told not to use solid trans mount. Not sure what to do.
any advise would help. thanks jim
Jim My wife loves pickup trucks
65' Impala, 65' Belair, 89' Silverado, 98' Silverado, 03' Silverado, 12' Silverado
Posts 24731
06-24-12 03:49 PM - Post#2240867
You can go either way. I see absolutely no advantage to a solid trans mount in most street driven cars.
In a high hp deal where you could have some frame twist on a drag race launch, a rubber trans mount might be a better deal.
greg_moreira
Posts 3262
06-28-12 07:08 PM - Post#2242417
Keep the trans mount rubber. Not that I have had it happen to me, but I have been told the easiest way to break a transmission case is with a solid mount, regaurdless of what is used for motor mounts.
FYI I run solid motor mounts on a fairly healthy BBC car with a rubber trans mount. No issues
Execution time: 0.096 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:00 PM
