| Username | Post: Cowel tag codes on 64 Impala Conv | |
buzguy Forum Newbie Posts 22 |
06-15-12 04:51 PM - Post#2237571
Can anyone tell me what these accessory codes are on this 64 SS Convertible I'm looking at: W K M R C F J Those are the accessory codes on the tag. I can see the car has air, PS, PB but that's all I can see in the pictures. PLEASE REPLY TO BUZGUY@GMAIL.COM Thanks, BuzGuy |
62sedan Very Senior Member Posts 3355
06-15-12 05:03 PM - Post#2237582
email sent
64 impala ss Contributor Posts 172 |
06-16-12 06:25 AM - Post#2237756
You might look here. http://www.348-409.com/acc2.html Dale |
grahamh Member Posts 49 |
06-18-12 08:32 AM - Post#2238665
Is it a Janesville built car? have you found out what the "J" code designates? |
06-20-12 05:02 AM - Post#2239372
Does anyone know what the accessory code "J" means on a Janesville car? |
06-20-12 08:00 AM - Post#2239424
I've not seen it listed on any assessory code charts. If the "J" code is on your own vehicle's cowl tag, but by reason of deduction, you may be able to figure out which option/assessory it equates to. Good luck.
06-20-12 12:55 PM - Post#2239500
J code doesn't show on any chart I have either. Dale |
06-21-12 12:24 PM - Post#2239837
I'm in the same boat. I've seen a couple cars with it and I can post the letters from the cowl tag, but I still haven't been able to figure out what a J stands for. Any input is appreciated! |
06-29-12 07:30 AM - Post#2242572
anyone else with info on this? |
