| Username | Post: engine/trans/driveshaft/pinion angle | |
Pistol "11th Year" Silver Supporting Member Posts 3558
06-08-12 12:57 PM - Post#2234808
So if my engine/trans is at 4.1 down in the back then the rear end should be up in the front at 4.1? I did add the front mount and tranny mount but I didnt change the spring perches, wouldnt that be more or less a factory setting?
