Back to Post
Username Post: roller tip fuel pump rod
johnod
Posts 45
06-01-12 07:48 PM - Post#2232398
Today I'm putting the engine back together. One of the things I wanted to add was the above mentioned fuel pump rod. This has a "bolt" which goes thru the threaded hole in the front of the block to keep the rod from rotating.
Simple right?
But.. the damn hole is blind, did Chevy change that sometime?
When?
Is there a fix i can do?
Execution time: 0.073 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:28 PM
