| Username | Post: HEI help |
IgnitionMan Frequent Contributor Posts 2415 |
05-29-12 09:32 AM - Post#2231101
Please be aware that there is a vacuum advance on that distributor, and possibly, it cannot simply "just be rotated a half turn" and re-firing ordered. You could rotate the dist TWO plug wire terminals worth, then move the plug wires two terminals each, that might you close to what you are after. Just have to work with it. |
