Back to Post
Username Post: Bell housing clutch linkage questions
Posts 24737
05-25-12 10:57 AM - Post#2229688
The front of the pivot ball should be 4-3/4" from the bellhousing mounting surface on the engine block. Period. Either you have the correct pivot ball or you don't - if the bellhousing mounts directly on the block.
The exception is if you have a block plate or mid mounting plate between the bellhousing and block. That's the only deal where you should be using an adjustable pivot ball.
Execution time: 0.081 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:39 AM
