| Username | Post: Harmonic balancer puller |
brokenhead Contributor Posts 162 |
05-23-12 04:32 PM - Post#2229087
the standard method of installation is to heat the balancer slightly, cool the crank, and use a hammer and wooden block or something to keep from dinging up the end of the balancer, The aren't really on that tight (at least in my limited experience) I taken off 4 of them and none of them were what I would consider an adequate friction fit. I never had to heat or cool anything, and it was no problem at all. I think mostly the fan belt keeps them from coming off...It seems to me using a real puller to remove would be the way to go, I'm sure they are available over there aren't they? They aren't expensive at all. |
