| Username | Post: commander 950 wide band ? | |
amkaperick Forum Newbie Posts 18 |
05-14-12 04:04 PM - Post#2225888
i am new to tuning i have the 700cfm tbi unit on a mild built 355 sbc. i bought the unit used on ebay it came with the wideband and controller... i downloaded the software from holly to my windows 7 laptop by the "run as administrator" method and have been tuning with it with some success. question is i bought a auto meter wbo2 to tune with because i wasnt able to figure out the holly wbo2.. with some searching on this site i was able to figure out how to set it up. so now that i have the a/fs just sit a 18-1 on the map is the sensor bad? sorry for rambling and if i didnt give the right info any help is greatly appreciated
Danny Cabral Member Posts 3142
05-15-12 12:21 AM - Post#2226024
Question is, I bought a Auto Meter WBO2 to tune with, because I wasn't able to figure out the Holley WBO2. Why not? It plugs right into the Holley C950 harness, and the software is already setup for it?
05-15-12 06:11 PM - Post#2226308
when i change to wideband on the software it just sits at 18:1 afr on the fuel map ????
zwede Senior Member Posts 1499 |
05-15-12 06:15 PM - Post#2226310
You have to check the output voltage curve of the wideband and then enter those values in the C950 wideband configuration. I.e. 10:1 AFR = 1V, 12:1 = 2, 14:1 = 4V etc.
05-15-12 10:48 PM - Post#2226397
ill have to check that when i get back in town sat. thank you so much for the tip i knew it would be something simple
