Back to Post
Username Post: No brake lites/turn signals
Bing Alcott
Posts 30
05-12-12 06:45 PM - Post#2225268
Acardon, taillites work. I alligator- clipped bulb socket to tailpipe, good ground, bright lite.I separated plugs and ck'd continuity at rear harness side of plug(pink and violet wires) and other side of plug which I wired into GM tilt column multi-wired plug,. All OK.I disassembled car 5 yr's ago and all worked well at that time. Ck'd new brake lite sw wire routing, looks OK.I'll hook-up front park lites and try again. Thanks for info....Bing
Execution time: 0.064 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:13 AM
