Back to Post
Username Post: Working on the wipers
one4dad
Posts 491
one4dad
05-12-12 09:46 AM - Post#2225145
My 51 styleline at one time had windshield washers and working wipers. I think I have disconnected and plugged all those washer vacuum lines (?). PO said he never intended to drive in rain ( impossible in south Louisiana) so he didn't worry about the wipers. So my approach to checking out wiper motor was to hook a directline from manifold to wiper motor. After working through different hose sizes, hooked it up and lo and behold the wipers moved one way and the only way to move the other way was to close switch. I thought I had bypassed switch so now I am somewhat more confussed. My size 200Plus, age, and 6'3" makes staying under the dash difficult at best. any suggestions/solutions. I have never been able to find a hose schematic for the wipers, etc.
Bill
Bill Wilson - 51 styleline Deluxe 2 door three speed , fentons and offy 2 carb manifold - is now a 235
Also a 1950 Chevy 2 door styleline deluxe, great patina , no running gear
arnieg141
Posts 6094
arnieg141
05-12-12 11:35 AM - Post#2225174
pull the glove box much easyer to work on it. they do have 6 and 12 volt motors if you want
2blu52
Posts 13093
05-12-12 01:19 PM - Post#2225194
I suspect that turning on the wiper switch allows the motor to vent. As I recall there is a vent outlet on the motor. The switch is just a off on control,the vacumn hose goes as you set it up direct from the manifold.
THOMAS JEFFERSON
Dean50
Posts 685
Dean50
05-12-12 01:47 PM - Post#2225199
I have seen posts that say put the carb end of the hose in some WD40 and work the wipers by hand to help lube the paddle inside.
There is also a fuel pump available with double vacuum outlets so the wipers won't slow down as you accelerate.
Dean50
arnieg141
Posts 6094
arnieg141
05-12-12 02:02 PM - Post#2225202
i think your right tom. but don't know if it vents or just reduces flo.running the hose direct is to much air
53belair
Posts 831
05-12-12 02:58 PM - Post#2225207
Just two words....Rain Gear. No more losing wipers everytime you hit a hill. No more cable and drum issues. Next to the disc brakes and open drive...this was the best investment I made in my car.
arnieg141
Posts 6094
arnieg141
05-12-12 03:12 PM - Post#2225214
dave you talking the polish coating like rain dance. it work pretty good BUT a trooper will give you a ticket if your wipers don't work and your driveing
Posts 4914
05-12-12 03:21 PM - Post#2225217
Dean, looking at your engine photo ..... is the acc. spring causing any "scuffing" on the oil filter hose ?
Dean50
Posts 685
Dean50
05-13-12 05:56 AM - Post#2225374
Thanks, Bob
Those are braided steel hoses so no problem there.
Dean50
53belair
Posts 831
05-13-12 07:22 AM - Post#2225399
Rain Gear is a wiper replacement system for our cars. It's electric and completely replaces the entire system (including the cable & drum and old transmissions). Everything bolts into the original bolt holes. The guy started making them for the tri fives and so many folks started asking for the earlier 50s that he made them for us too. Comes with the switch but you can upgrade for a intermitent switch if you desire.
Here is a link to their site. http://www.pacificwesterndesign.com/
arnieg141
Posts 6094
arnieg141
05-13-12 09:26 AM - Post#2225446
ok i got you. electric wipers 4 the 49 to 52 and the 53/54 are out there by alot of companys.
one4dad
Posts 491
one4dad
05-13-12 03:03 PM - Post#2225518
I checked out the web site and they don't offer replacements for 49-52 they start at 53. Looks like a good product.
arnieg141
Posts 6094
arnieg141
05-13-12 04:01 PM - Post#2225537
http://www.ebay.com/itm/1949-1952-Chevy-W iper-Moto... http://www.ebay.com/itm/1949-1950-1951-19 52-NEW-ch...
one4dad
Posts 491
one4dad
05-13-12 04:23 PM - Post#2225551
Thanks for the link, After struggling under the dash and with no better results, this might be my best option. Might need to hold off , because now I have a brake fluid leak........
Bill
50hotrod
Posts 366
50hotrod
05-13-12 05:14 PM - Post#2225568
  • arnieg141 Said:
I have this electric wiper conversion. Works perfect and Kenny's Rods are great people to deal with. Please note the electric wiper motor listed is for 12 volt.....
arnieg141
Posts 6094
arnieg141
05-14-12 03:04 AM - Post#2225687
  • bouncer Said:
bouncer i don't know if he has his car converted to 12 volt so i looked up 6& 12 VOLTS FOR SALE
Sir X Loin
Posts 239
Sir X Loin
05-14-12 07:33 AM - Post#2225750
  • arnieg141 Said:
Does anyone have experience with either of these motors? Are they truely bolt in? Designed for the stock linkage.
1957 Chevy Pickup 1998 -2012 *sold
1951 Chevy Styleline Deluxe
arnieg141
Posts 6094
arnieg141
05-14-12 08:11 AM - Post#2225767
i have its as easy as if you where replaceing the stock one you have with another one .do it thu glove box mostly .
Mike JW
Posts 911
Mike JW
05-14-12 04:44 PM - Post#2225901
Put one in my 50 coupe. Was even able to use the stock wiper (switch knob) you would never know except that now they work.
It truly is a bolt in was fairly simple
one4dad
Posts 491
one4dad
05-14-12 04:49 PM - Post#2225902
Thanks for the info and the report to verify installation. Bill
one4dad
Posts 491
one4dad
05-14-12 05:38 PM - Post#2225919
One more question...In the Chevs of the 40's catalog it states that their electric wiper motor can't be used with the stock radio. Was that your experience with the wiper motor you installed? I have converted to 12 volt,,..Bill
Mike JW
Posts 911
Mike JW
05-15-12 06:10 AM - Post#2226083
I have the Stock radio (head) in my dash but an after market radio radio under it. so can't answer for sure about that. Mike
gbafus
Posts 1261
gbafus
05-20-12 07:40 PM - Post#2228030
The conversion kits you see on ebay are made by Newport Engineering, NOT Raingear.
http://newportwipers.com/
http://www.pacificwesterndesign.com/RainGear/index...
George
Chevrolets previously owned:
1947 Fleetline Aerosedan
1955 Bel-Air 4 Door Sedan
1958 Biscayne 2 Door Sedan "Maybelle"
1977 Monte Carlo
one4dad
Posts 491
one4dad
05-26-12 03:37 PM - Post#2230101
My boys gave me an electric wiper motor from Kenny's Hot Rods made by New Port Engineers. Went in without having to remove stock radio ( doesn't work, but didn't want to ruin looks) and with some small issues like 250# plus men working under dash. Has a small screw in way that was holding the mount for the guide PRISM for seeing around the Visor. PO had it mounted in center ( not sure if was in stock location) Reloctaed it and motor went in good no issues except the small clips to secure transmission arms being somewhat difficult with big hands....works like a champ - two speed __ Glad it's done
Lead sled
Posts 1510
Lead sled
05-27-12 05:59 AM - Post#2230257
I JUST put one of these Newport's in mine last week,all went well,except for those tiny E clips you mentioned. I don't know how it will work yet though. I still haven't got the dash/gauge panel wired back up,(hopefully this week)so no power to anything yet.
51 BelAir 2drht 52 trim.Basically stock 67 Camaro SS350/295hp Turbo Fire Edelbrock 1405,Saginaw 4spd/355 geared 55/6 Chevy rear.I just finished all the bodywork/paint myself.2,1st place trophies so far
Execution time: 0.087 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:59 PM
