Back to Post
Username Post: Bank 1 reading lean
Tritip
Posts 44
Tritip
05-04-12 05:47 PM - Post#2222508
What would fix this? It happens every now and again. Twice both 1 and 2 read lean. Is there anything I can do to fix this. Other then clearing the codes when they pop.
1996 350 5.7L 80MM throttle body, aftermarket mass Air flow, K&N full intake, MSD Coil, and short Headers.
I replaced the O2's about 30,000 miles ago maybe less.
96 Chevy 1500 5.7l
Posts 23555
05-04-12 06:05 PM - Post#2222515
Checked fuel pressure lately? Still running the original poppet valve setup and how many miles are on that?
ltlvt
Posts 1583
05-04-12 06:27 PM - Post#2222524
As small exhaust leak will bleed O2 into the system causing the ECM to think it is lean.
Runs like a Scalded Dog!!
Tritip
Posts 44
Tritip
05-05-12 08:15 AM - Post#2222678
I have not checked the pressure as of late (if I remember correct, should be 52psi?). The original Poppets are still on there, rolling with 111340 mile as of yesterdays drive home.
**I don't think there is an exhaust leak (I will double check)**
96 Chevy 1500 5.7l
Posts 23555
05-05-12 03:39 PM - Post#2222852
Fuel pressure info in the FAQ but short and sweet, factory spec is 58~62 psi on the Vortec small block.
Execution time: 0.103 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:10 PM
