| Username | Post: Stupid Gas Tank Question | |
technitom "2nd Year" Silver Supporting Member Posts 248
04-29-12 10:38 AM - Post#2220241
if you are sure its the cap, I'd go ahead and replace it. A little trick I have used is folding up a paper towel 'til its about 1" wide and about 1/2" thick, then wraping it around each line (supply, return, filler, fuel pump, etc) using a zip tie to hold it in place... romp around a little, some figure 8's, hard launch, and stops.... then checking out the towels
