Back to Post
Username Post: engine popping sound
FlyinRed7
Posts 1594
04-18-12 02:19 PM - Post#2216575
My 350 SBC w/ new Vortec heads and flattop pistons, Mallory Uniilite, ceramic headers and Edelbrock 600 cfm carb on an air gap type intake is starting to pop and crack at 1500 + RPM. It doesn't seem to have the power it should either and I think it is running too lean. Nothing has been done to the carb since it was last used on this engine before the general overhaul from a basic stock 76' Camaro. The cam was replaced with a Crane 272H @.454 I/E so it's kind of tame but should work well on the street.
I am really unhappy with it and have a new set of wires and plugs for it which I'll put on soon but don't think thats the problem. Also my 700R4 tranny vibrates in OD only but smoothes out if I pull it back to direct. What is going on with that? My rear is stock 3:55, perhaps a little too high? It has not been set to lock up the converter FWIW.
Any help is much appreciated. Thanks guys.
57'-2454 355/700R4 53' Chevy 5 window P/U 01' Z28-SS 6sp/ 04' GMC Sierra 62' Corvette convertable www.picturetrail.com/Birdhtr
Allan In NE
Posts 904
04-18-12 02:29 PM - Post#2216582
Nothing wrong with your transmission, it's just reflecting that engine miss.
Popping out the carb?
You've got troubles with the valve train on an intake valve. "Usually" a flat cam, bent pushrod, broken rocker, broken spring, etc., etc.
Allan
Lifelong GM automatic transmission specialist
FlyinRed7
Posts 1594
04-18-12 02:37 PM - Post#2216584
Pops out the exhaust but it did backfire a couple of times.
Allan In NE
Posts 904
04-18-12 02:49 PM - Post#2216589
Okay,
Disregard the "intake" stuff. Find that engine miss. There is absolutely nothing in that tranmission that can "vibrate".
Allan
FlyinRed7
Posts 1594
04-18-12 02:54 PM - Post#2216593
The driveline is new and good all the way as is the angle and phasing. Something is damn sure wrong. Is it possible that the converter could be bolted up wrong to the flexplate? I mean does it have to go in a certain position. As you can tell I'm not a tranny guy but I do know drivelines well.
MikeB
Posts 9388
MikeB
04-18-12 02:56 PM - Post#2216594
I'd double check valve adjustment. You may have put too much pre-load on one or more lifters. Very easy to do with a new lifter that's not full of oil.
I like to tighten the nut very slowly until the pushrod no longer moves up and down, then loosen the nut to double check that you were at zero lash and NOT BEYOND THAT. Then take out the lash again and go down 1/2 turn or whatever Crane recommends.
Let us know what you find.
Real Hot Rods have a Clutch!
1969 C-10 pickup: 350, TH350
My car pictures
Allan In NE
Posts 904
04-18-12 03:03 PM - Post#2216595
Yes, possible.
If the converter is out of lop with the flywheel, it will vibrate in neutral/park just off idle.
Still think you have an engine miss, especially so, because it really shows up in overdrive.
Like the other gent said, recheck your valve adjustment and do it with the engine hot and running.
Allan
Old_Longboarder
Posts 12225
Old_Longboarder
04-18-12 03:12 PM - Post#2216602
If the popping, sounds like a machine gun firing as engine RPMs increase, you have an exhaust valve that isn't opening.
"The most precious jewels you'll ever have around your neck are the arms of your children."
Allan In NE
Posts 904
04-18-12 03:15 PM - Post#2216605
Yep,
Same as the intake "rat-a-tat-tat".
Allan
jk56chevy
Posts 820
jk56chevy
04-19-12 09:01 AM - Post#2216875
Just a shot in the dark, don't ask me how I know, if your coil is mounted horizontally, that can cause sounds like that.
1956 Chevy Belair
FlyinRed7
Posts 1594
04-19-12 11:07 AM - Post#2216923
I'm pretty sure it is a valve adjustment issue because I just had that done by a guy who is supposed to know his apples but I swear it doesn;t run as good as I had it. Could possibly be a lobe wiped but I did run it in for about 20 minutes at 2K when I first got it running. That doesn't guarantee anything I guess so I'm going to check that also. If the guy really tightened the lifters down I guess he could even have bent a pushrod. Thanks for the input everyone and for confirming what I've been thinking.
Alan...I'll check the converter/flywheel bolt thing. Thanks.
ps..the coil is vertical but thanks for the thought.
tri5ss
Posts 2546
tri5ss
04-19-12 11:58 AM - Post#2216934
How about something as simple as a broken/cracked distributor cap or a bad/worn rotor. My old motor did the same thing a couple of days before it actually quit. Fix, new cap and rotor. See if you have any "black" spots on the inside of the cap and look for wear marks on the rotor. You may get lucky and find it's a quick and relatively inexpensive fix.
Good luck,
Randy
Tri5SS
'55 210, GMPP ZZZ, 200 4R, 12 bolt 3.73 posi, CPP P/S, ABS D/B.
http://www.picturetrail.com/tri5ss
Nothing is foolproof to a sufficently talented fool!
MikeB
Posts 9388
MikeB
04-19-12 12:05 PM - Post#2216936
There's not necessarily any damage done, but I'd certainly look at all rocker arms and pushrods. Once you find the problem, you can check lobe lift at that pushrod, which for your cam would be .302". Don't try to measure lift at valve unless you have a light test spring, because a regular valve spring will compress the lifter internals when there is no oil pressure.
If your lobe lift is OK, I'd say the cam's OK. Lobe wouldn't get damaged unless it was trying to push against a coil bound valve spring. So if your springs are good for, say, .480" lift + .060" safety margin, you might be OK. Then again, if a piston hit a valve...
My car pictures
MikeB
Posts 9388
MikeB
04-19-12 12:07 PM - Post#2216937
Good idea.
My car pictures
FlyinRed7
Posts 1594
04-24-12 03:05 PM - Post#2218727
Rocker arms, springs, pushrods all OK & the cam lift appears equal. Replacing plug wires and loom. Hoping this does it. It does run better but still has a lifter type noise but all are adjusted properly. The noise is not necessarily a clicking but is just noisy almost like mechanical lifters.
Any thoughts
retiredrich
Posts 792
retiredrich
04-24-12 05:02 PM - Post#2218763
Any thoughts
Try putting a stethoscope down in the fuel pump area and also the push rod for it.
FlyinRed7
Posts 1594
04-28-12 09:13 AM - Post#2219943
"Try putting a stethoscope down in the fuel pump area and also the push rod for it.
Not a bad idea and I'll try it. Thanks.
beejay
Posts 12550
beejay
04-28-12 12:01 PM - Post#2219977
Well, I'm gonna go a different route. Try replacing exhaust/header gaskets. They go rat-a-tat-ta, also, and don't asking how many of the wrong ones I changed before getting the right ones installed. I replaced both, one bad, one not so good.
Bruce
http://www.picturetrail.com/beejay3/"
Execution time: 0.177 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:05 PM
