Back to Post
Username Post: hard to turn right under load
64belaire
Posts 160
64belaire
04-16-12 12:54 PM - Post#2215794
This bug is driving me crazy. When both front tires are on the ground its hard to turn right. Pick the right tire up and its easy. I know the alignment is off a bit but Im tinking the assist ram is going bad. If i let go of the wheel while driving it shoots left. When sitting still and rev it the wheel will also try to turn left.
Im guessing either the ram is bad or a bad line.
Anyone else run into this issue?
Execution time: 0.067 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:49 AM
