Back to Post
Username Post: Need some trans help ASAP
awsum55
Posts 8838
awsum55
04-03-12 06:23 PM - Post#2210952
My son called me from Disney World today and his 2003 Suburban is making a chirping noise when it warms up. He said when he first starts it you can't hear it, but within a few seconds you can hear it and it gets louder.
He said with the radio on you can barely hear it, but when stopped at a light or going slow (like when in Disney) other people in cars were looking around to see what the sound was.
He said it still drives and shifts like a dream. He said the noise sometimes sounds like the fins on the torque converter hitting something.
He is pretty mechanical, but he is 1500 miles from home and only has a few tools. He said he will jack the truck up and use a spare for a jack stand and then pull the inspection plate and see if he can see if a bolt backed out or something easy.
He called a shop and they told him the trans would cost 3k and it would be $800 to install it. He told me he wants to go buy a tranny and install it himself, or rent a trailer and tow it back home.
I told him I would ask here if there is anyone that knows what he can check or if anyone lives close enough that he could borrow a jack and some stands to check the truck out.
Obviously this has a high priority for him, so any help would be appreciated.
Five things that you cannot recover in life:
* The Stone after it's thrown
* The Word after it's said
* An Occasion after it's missed
* The Time after it's gone
* A person after they die
awsum55
Posts 8838
awsum55
04-03-12 06:58 PM - Post#2210966
I don't know if this will matter or not, but the truck is a 1500 series with a 4l60E and 4 wheel drive.
Posts 23559
04-03-12 07:29 PM - Post#2210984
Sounds can travel - before he assumes it's the transmission he might want to slip the belt off and try running it for a moment without it.
awsum55
Posts 8838
awsum55
04-03-12 08:30 PM - Post#2211011
Sorry, I forgot to mention he did tell me he pulled the belt and the noise was still there.
Allan In NE
Posts 922
04-04-12 01:10 AM - Post#2211081
This is an age-old, classic Chevy "noise" and that shop is just flat trying to screw 'im out of four grand.
Tell him to go ahead and drive the truck home and then put a new flywheel in it, as his is cracked.
He can just back the transmission/transfer case rearward, as a unit, about 4", which will allow enough room to slide a new one up and in. The slightly protruding "lip" at the center of the flywheel goes to the rear.
Allan
Lifelong GM automatic transmission specialist
awsum55
Posts 8838
awsum55
04-04-12 06:37 AM - Post#2211146
We spoke again last night and he is going to bring it to a guy he met that has a shop. He said he seems like a good guy, so we'll see how that works out.
I figure it's better to spend a few dollars and see if he can tell what's up. I hope he can get the truck back home without incident and take care of the problem himself.
Thanks for the responses.
Execution time: 0.079 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:43 PM
