Back to Post
Username Post: 500 Series box - custom rag joint - Ididit column. How I got a perfect fit!
1956chevy
Gold Supporting Member
Posts 286
1956chevy
03-26-12 05:21 PM - Post#2207805
The column is mounted in the stock position using the stock dash mount. On the last photo above you can see the Ididit lower column mount under the column.
I was not able to use the factory threaded nuts to secure the lower column mount to the firewall, as they had been drilled out. Since I had to use nuts and bolts I positioned the bolts inside the firewall. This way I will not have a problem getting the seal over them.
As for the hole, I am using the factory column seal and firewall seal.
Here is the column ready to go in. I have not attached the seals to the firewall yet. (Yes, the column mounting clamp is on the wrong side of the seals. I found that out later. )
I will clean up the over spray on the firewall around the opening in the engine compartment. I realize that Eckler's sells a polished stainless lower column mount that mounts from the engine side, and covers the whole area. I considered that, but wasn't sure how much clearance I would have. The old 605 box and column I removed had a piece of sheet metal bolted under a massive power brake booster that covered the opening. It was really a nightmare working on the steering with that in the way.
Yes, they also broke all the studs off the pedal assembly when they mounted that brake booster. I have replaced the pedal assembly mount after painting it and rebuilding it.
Keith Marang
Webmaster
Central Oklahoma Classic Chevy Club
www.55-57chevys.com
Execution time: 0.308 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:31 PM
