Back to Post
Username Post: ses light- repair?95 c2500
trac
Posts 8
03-03-12 08:24 AM - Post#2197871
ses light- never have seen that,, does anyone know what color wire's to even look for,, or can someone explain how to check this,, or how to take the dash apart to replace the light. when u turn the key on it should come on,,, never have seen it,,, doesn't come on when u jumper the obd1, either-matter of fact,, i've had two different people try to pull codes,,- nothin -
Posts 23555
03-03-12 04:47 PM - Post#2198044
First thing of course would be to check the bulb. 95-up the dash bezel simply pops off towards you but be very careful to not smack the hazard button with it as the button assembly is very, very fragile. Carefully angle the bezel around to get it out of the way and you won't even need to unplug the headlight switch. If your truck has aux switches to the right like cargo light, etc. you'll need to unplug those.
Dash cluster is held in with 4 screws. Remove those, pull cluster out, and you'll see on the back where the bulbs are marked. They twist out...you can buy new twist-in bulbs at the auto parts store. Take the old one with you as there are a few different sizes.
trac
Posts 8
03-04-12 08:08 PM - Post#2198558
k,, I'll try it,, thanx!
Execution time: 0.062 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:56 AM
