Back to Post
Username Post: Lousy AC vent fit normal for a 57?
Belair-o
Posts 80
02-09-12 02:13 PM - Post#2188834
I bought a set of the dash-mounted AC vents for my 57. I used the template to locate the holes in the dash, but the vents sure don't come close to snugging up to the dash - the shape of the vent could never match the shape of the dash. Is this quality of fit normal?
Thanks, Doug
62chevy427
Posts 1516
62chevy427
02-09-12 05:23 PM - Post#2188914
are the vents aftermarket? if so,poor fit is not unusual.try trimming the vents to match the dash. i just installed new dash trim on a 56 and a 55. supposedlu good stuff,but i still had to work on the ends where the screws go to make them fit the dash.
56 bel air ((since 2002)
62 impala ss (since 1965)
65 el camino (since 1969)
66 nova (since 1987)
83 gmc 4wd (since 1991)
95 impala (new)
11 malibu (new)
Posts 24809
02-09-12 05:32 PM - Post#2188920
The 55-56 vents fit pretty good, and I've seen some 57s that did. Never heard any complaints previously.
Belair-o
Posts 80
02-10-12 04:39 AM - Post#2189039
The vents are aftermarket, and pricey. I guess that's the way it goes. I don't see that trimming is an option on these cast vent outlets.
Thanks for your thoughts. Doug
patrick_rodgers
Posts 3972
patrick_rodgers
03-14-12 07:11 AM - Post#2202393
What I did on my factory ones, is a lot of die grinding. Wrap masking tape around the backside of the face, and see where it hits, grind, and keep doing it until you are happy.
1957 Sports Sedan and Nomad
2005 Subaru Legacy wagon (built in Indiana from parts made in the US)
CharlieC
Posts 1748
CharlieC
03-14-12 09:25 AM - Post#2202436
Just to mention w/o starting a new thread, I got my OE AC vents rechromed by Iverson Auto in MN for $150 couple weeks ago. They look great.
Mine seem to fit OK as is.
Also, anyone know why the backside side of the vent where the hose will connect is so much larger on the driver side vs pax? I'll need to find some way to neck it down.
Charlie
'74 K5 Blazer 4x4
'09 Avalanche LTZ
WagonMan
Posts 1296
WagonMan
03-14-12 10:44 AM - Post#2202467
I think it is due to the distance from the evaporator so the larger mass of air stays colder longer and helps equalize pressure with the shorter passenger side.
Charles
57 210 4dr. Wagon(bought '82)
-350/700r4 Mild Custom
56 BA 4dr. ht.(bought '98)
-265/TH350 Mostly Stock
29 Ford Sedan(bought '75)
-4.3L/TH350(in progress)
53 Chevy 3100 (bought '96)
-250 I6/TH350
Posts 9470
03-14-12 11:47 AM - Post#2202493
Charlie, Classic Auto Air in Grapevine has the adapters. I also think it's to get as much air to the drivers side due to the distance. On the original system there was a 3" hose to the drivers side. Link to original A/C. I have the OE vents also and when I first installed it, I got very little air out the drivers vent, so I put a 2 1/2" hose from the evaporator to the drivers vent with an adapter on each end. It helped the amount of air, quite a bit.
57 2dr HT (restoring)
CharlieC
Posts 1748
CharlieC
03-14-12 02:45 PM - Post#2202580
Thanks Don. Interesting pic of the OE system there. Sure was a long run.
Charlie
'74 K5 Blazer 4x4
'09 Avalanche LTZ
Posts 24809
03-14-12 04:43 PM - Post#2202621
Don, are the VA hoses to their vents 2" diameter?
I could go look, easier if you tell me.
Posts 9470
03-14-12 05:02 PM - Post#2202634
I have Classic Auto Air, but I think Vintage uses 2" hoses also. I adapted the 2" to 2 1/2" on the long run, hopeing it would have less restriction.
Posts 24809
03-14-12 06:46 PM - Post#2202692
It probably helps, even if the outlet fitting on the case is 2".
Execution time: 0.135 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:49 AM
