Back to Post
Username Post: Help in identifying an injector
Madness
Posts 34
11-04-11 03:35 PM - Post#2154499
I have a set of injectors here that I can't seem to find out any info on. They have a part number 01D111B on one side 0409 on another side. They have a stainless body with a black plastic top/plug. They are standard size injectors, not a pico type. They look like this http://www.summitracing.com/parts/TFS-89036-1/ at summit by Trick Flow. None of their part numbers coincide though. Does anyone know who's they are and what the specs might be?
Thanks for any help, Mark
Danny Cabral
Posts 3149
Danny Cabral
11-06-11 04:44 PM - Post#2155149
I believe those are Accel 32 lb/hr fuel injectors:
http://store.prestoliteperformance.com/32lb-single... (image is for reference only)
http://www.thirdgen.org/techboard/engine-driv etrai...
May God's Grace Bless You
'78 BRONCO: 508" stroker, TFS heads, Dominator MPFI & DIS, A/C, Lentech Strip Terminator AOD, 3:1 Atlas II, modified Dana 44/60-lockers-4.10s, hydroboost/4-disc brakes, ram-assist/heim-over steering, 4" lift, 35" tires
Madness
Posts 34
11-11-11 03:50 PM - Post#2156991
That is what they look like. Is there any reason why you think they are 32 lb vs 30 lb. I mean in their catalog they use the same photo for all of them, and I didn't see their part number corresponding with what I have. In the photo you can see the numbers are the same place as I have on mine, but mine are different numbers. Do you know where the 01D111B number crosses to a 32 lb?
Thanks for anything further Danny, Mark
Danny Cabral
Posts 3149
Danny Cabral
11-11-11 04:00 PM - Post#2156994
The Accel link I posted, states they're 32 lb/hr injectors.
http://www.hptuners.com/forum/showthread.php?t=289...
Madness
Posts 34
11-11-11 08:20 PM - Post#2157092
Danny, what I am getting at is what made you go to that link? If I go to part number 150130 I get the same picture, description and so on. The only difference is those are 30 lb injectors. I believe you are right they are Accel in looking at how they mark their injectors, but how do you reference the 01D111B to a 32, 30 or even a 36 lb? Did you find something that I am missing that takes the 01D111B number and shows that number is a 32 lb? Maybe I am just thick on this.....
Danny Cabral
Posts 3149
Danny Cabral
11-12-11 02:01 AM - Post#2157147
http://www.hptuners.com/forum/showpost.php?p=21284...
http://www.thirdgen.org/techboard/posts/engin e-dri... & http://www.thirdgen.org/techboard/posts/engin e-dri...
Madness
Posts 34
11-12-11 01:24 PM - Post#2157327
Ok, thanks Danny...
Execution time: 0.101 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:37 PM
