Back to Post
Username Post: 1971 Impala blinker & emergeny flasher
ygarcia310
Posts 6
ygarcia310
09-30-11 02:58 PM - Post#2142632
My 1971 Impala blinkers are both solid, they are not flashing on the outside (front or back. Also my emergency flashers dont work at all. This) just happend 2 day ago, no ones touch my wiring. I did check all bulbs, and fuses, all are fine. However when I tested the fuse housing for hazards/tail lights my tester didnt light when I place my tester on the hazard side. I test all fuses, and tonight Im going to replace all the bulbs. Im posting this message hoping to get help if new bulbs dont fix the problem.
Proud owner of a 1971 Impala Custom
caprice513
Posts 365
10-05-11 05:20 AM - Post#2144035
regular bulbs or LED? when I put the LEDS in mine I had to have a relay put in to make them work
ygarcia310
Posts 6
ygarcia310
10-13-11 08:58 AM - Post#2146899
Regular bulbs, I didnt convert anything. Noticed they werent working one day, so changed out all the bulbs. Over the last few days I went over the wiring again when I wiggled the driver side front blinker & the bulb would flicker on and off. I looked for any damaged wires but didnt see any. Could be be a bad ground?
Execution time: 0.072 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:59 AM
