| Username | Post: Fender Mender (68 b-body fender fix) | |
RaysnCayne Frequent Contributor Posts 1001 |
05-21-10 08:30 PM - Post#1918633
back side, wire brush as good as possible and use the POR 15 Okay Bill, your reply was one, big run-on sentence. I want to be sure I'm parsing it correctly when it comes to the back-of-the-patch-panel-p rep, just POR-15 it before I weld it in. And then do all that other stuff (to the outside) after it's welded in, right? And Yeni, if I understand your vague reply, it's that I should just slap the filler right to the bare metal and go, y/n? I went down to the Body and Paint section and it appears there's two distinct schools of thought on this subject. Lots of guys say put the filler straight on and go others are saying use epoxy primer to seal then do filler. I would've thought the restoration industry would've figured this one out by now! But it seems they're still very much in the middle of this debate. Hey Steve (67SS427), you out there? What's your thoughts on this?
