Back to Post
Username Post: Vacuum Advance- how is it supposed to work?
IgnitionMan
Posts 3219
04-05-10 04:24 PM - Post#1893473
NOPE, one thing not confirmed, LIMIT THE AMOUNT OF PULL PIN TRAVEL ON THE VACUUM ADVANCE, or, there will be way too much vacuum advance timing when it is plugged into full manifold vacuum.
For a 383, 8 crankshaft degrees is all needed to supplement the initial timing, and that is limiting the pull pin to .086 of an inch travel.
If anyone wants pictures of a stop YOU can make at home, and how to measure the stop distance, send me an e/mail. Let me know which type of distributor you have, large cap HEI, or small cap points type, ask for the vacuum advance stop pics, and they will come to you at no charge, no obligation. Use this e/mail address:
info@davessmallbodyheis.com
And, the whole timing and vacuum advance dissertation above, "TIMING AND VACUUM ADVANCE 101", came from a former GM development engineer, another person who also posts here, but did not add to this topic.
Execution time: 0.22 seconds.   Total Queries: 11   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:36 PM
